clutch cable replacement
Can anyone tell me if the clutch cable fitting that goes into the clutch release cover is different on each softail model? I have an '03 FXSTB Night Train and I need a black vinyl coated clutch cable with black fittings 10" over. That's 68" housing length with straight ends, no elbows. I can't find one that they say will fit a Night Train. Will one for a different model work?
I appreciate any help cuz I'm stuck.
Thanks.
Thanks.
Here is your oem part number 38665-00
http://fiche.worldofpowersports.com/...VER%20ASSEMBLY
Here is an 03 Fatboy oem number 38666-00
Here is your night train clutch cable from Drag Specialties it states lenght and application.
http://www.dragspecialties.com/produ...umber=06521473
Her is Drag specialties cable for the 03 Fatboy which is described as 7" longer but everything else looks the same.
https://www.mxmegastore.com/drag-spe...CIoaAoVi8P8HAQ
Found a 68"er it's for a 94-2000 FXDL oem Number 38602-92.
Drag Specialties description of oem number 38602-92
http://www.dragspecialties.com/produ...umber=06521456
The only differences should be where the adjuster lines up to your frame.
I would find an HD dealer that stocks both and physically check them....
Hope it helps.
Hope it helps.
FrankEV
02-08-2019 09:31 AM
Iron lHorse
08-01-2017 12:08 PM
