Softail engine- transmission removed/installed together
I'm about to install the entire drivetrain in a softail. I'd like to install it together. It appears that it was removed with the engine and primary and transmission together. I'm wondering who's done it, which side it's installed from, and if there is anything I need to be aware of.
I'm familiar with separating the engine, primary and transmission, but why would I want to go there if I don't need to? How should it be approached?
Never mind....can't be done.
