oil leak
Inner primary bearing seal; main shaft/5th gear seal; MDG seal. Anyone of those could be the source of the leak. If the leak is oil, the inner primary bearing seal is gone. If the leak is trans fluid, one of the other two is gone. Not a tough repair; parts are cheap but time consuming and dirty work.
Yep looks like IPBS area. I have a brother that puts different liquids with different colors in the engine, trans and primary so if there is ever a leak he knows what hole it's coming from by the color of fluid used. If the primary leaks its pink if trans leaks purple and the the engine with syn oil. ( ok so before some starts to talk about the colors of liquid could be reversed in colors but you get where this is going ) Kinda smart keeps from guessing where leak is coming from.
Towy4u
05-30-2020 12:35 PM
eddbenson
06-19-2012 12:42 PM
