Transmission oil weight
Which oil and weight would you suggest for the transmission in a 2004 Heritage Softail FLSTC used in mid florida? Harley specs call for Part No. 99892-84 quart .
Thank you in advance!
PS: I just replaced the factory installed Dunlap tires [13,000 miles original miles] with Michelin Commando 11. WHAT A DIFFERENCE in the ride and handling!
corliss@bakerdrivetrain.com (10-24-2019)
Spectro Oil BD-75140
Recommended Fluid / Level
Picking the right transmission fluid ensures the life and durability of your transmission, that’s why BAKER recommends a fully synthetic GL-5 rated gear weight oil of 75W-140. If a GL-5 rated gear lube is not available, these commonly carried viscosities (weights) will work 75W-90, 75W-140 and 85W-140. BAKER does not recommend the use of Syn3 (20W-50). For Bert’s article on ‘Oil & Spiders’ Click Here
BAKER DD6 Fluid Capacity Dry: 22-24fl-oz
BAKER DD6 Fluid Capacity Wet: 18-22fl-oz
Installation Instructions
DD6 installation instructions with exploded views: Click Here
