Easier Clutch Pull Options
I just replaced my stock 96" motor with a 117" and installed the Barnett Heavy Clutch spring with a Barnett Extra Plate Kevlar clutch pack. The pull on the damn clutch lever is gonna have my left forearm looking like Popeye it's so stiff. Are there any options out there where I can keep the spring tension needed in the primary but not have such a stiff lever pull?
Yes! Even Barnett have an option. See this thread for a few details. Read it right through, also use Search in the Touring forum for 'VPC', as that will bring up other threads with options for clutches.
NascarGuy (03-22-2016)
There are other devices available, but I don't recall brand names at present. Follow my earlier suggestion, which should uncover more options! You will find you are spoiled for choice.
What's the deal with people thinking the Screamin' Eagle Spring is so hard too pull? If your having that hard a time with pulling the clutch maybe you oughta go hydraulic... Lube the clutch cable, throw the spring in and Ride... Damn I can't tell much difference in pull between stock or Screamin' Eagle....
Depends how big and strong you are, we're not all 300 pound muscle-bound hulks! For those of us who need a bit of help, there are several devices available, although more than mentioned in this thread. Compared with most other brands of bike a Harley requires a strong clutch hand.
https://www.hdforums.com/forum/tri-g...-adjuster.html
