'N' light on in 1st and 2nd, off in neutral
I'm working on an EVO softail that has N light on in 1st and 2nd and off in neutral. When the switch is tested, it has continuity between the poles when the button is pressed. Did HD make another switch that works the opposite of this? That seems to be the issue that it is doing the opposite of what it should be doing.
Mark, that's part of the problem, we don't know what year it is, does not have a VIN on frame. It is a project that a customer bought and brought in that has been altered a lot and we are getting it running and road worthy. It has the black bodied switch which as far as I can tell is for 00 & up, although the silver bodied switch seemed to have a very limited application. Thanks for your help.
