First time chain breaker use
New/spare master link, but not really needed if you plan on using the old one. Technically, your not supposed to re-use the master link clip but I have never had an issue unless it gets bent upon removal.
Are you removing the link because it has stretched? Check it for wear and slop. Now is a good time to clean it and re-lube. YD
It's always been long, but I used a slop wheel to control it. I am now fitting a sprokster sprotor and the calliper can't sit that far back in the triangle of the swinging arm otherwise it will foul the swing arms substantial webbing. So I need to take up the slack, I can pul the chain up the cog by a link easily, I may be able to pull it up another link. I need to have the axel as far forward in the slot as I can really to give be scope for adjustment.
Steve
Steve
Greenblood (06-09-2016)
