need clutch help/diagram
Need clutch help and an exploded view, diagram with the exact plate sequence before and after the spring plate. Here is the big issue. I have two friction plates with friction pucks on only one side. Is this normal? or do these plates need replaced. if they are supposed to go in there, how are they oriented. I got stuff all mixed up when trying to get the old broken spring plate out. any help would be appreciated.
Welcome to the Forum from Colorado!
Since we have no idea what you're working on, I will give you this link to an exploded view. I hope it helps. Good luck.
https://www.google.com/url?sa=t&rct=...dccj5xGPWcTdXQ
