Why was this Thread removed ???
just trying to help where we can !!!
you're very welcome ...!!! if by chance it dose not work ...check the clutch adjustment ..if the clutch is dragging a little or the clutch plates are stuck together for some reason ...that will still give you that hard shifting ,because the clutch is still wanting to pull the transmission even while the lever is pulled in...
Your thread is still there. I just checked. You need to go to Display Options and tell it you want to see more threads than just the last day.
springers4ever (07-25-2016)
