Pulley fittiment question
Can anyone tell me what pulleys will work on my 2016 SG? I want to lower the gear ratio to a 30/68 or 30/70. Ive looked at some aftermarket stuff and think i could get stock take offs for cheaper. Are the off set and bolt pattern pretty common or are there only certain bikes that will fit mine. Also any help with a place that may have decent deals would be helpful. Thanks in advance for your help!!
Yea we have both the 30 and 31. Not sure but the rear pulley on the 16's may still be the cush drive. Where the pulley is cast into the wheel. I'll look it up.
Belt fitment rule of thumb is this: drop one tooth and keep the same belt. Drop two teeth and you will have to drop one tooth on the belt.
Yes i do have the 68 tooth rear on my bike now acording to the manual. I dont think the resr pulley is part of the wheel because i had them change the wheels when i bought the bike and i dont believe there was a pulley on the stock take off. Cant remember for sure and im not home to look at it now. Thanks for your help. Sure is appreciated. Im doing to 110" kit this winter and want to get the most i can out of it. I dont need to go over 100 mph very often but i do like to be the first on there!!
Montamayor (04-07-2018)
Did you only change the transmission pulley? Maybe im wrong in my thinking but cant i add teeth to the rear to offset taking them off the trans? Like go with a 30/70 set up? And i havent ever priced belts are they that expensive that people are worried about changing them or is it more that they are harder to get than a stock belt?
Unfortunately there are very few options where pulleys are concerned. I don't know of a 70T for your model year, except the one on the trikes, but they use a wider belt, which isn't much help!
deadhawg
08-20-2023 07:07 PM
Road King Kid
05-07-2010 05:21 AM
