new gasket leaking
new gasket leaking
I recently had a buddy rebuild my rotary top 4 speed transmission. Along with doing that, he replaced all the gaskets. The shifter shaft cover gasket seems to be leaking 15 miles after rebuild. How tight can I go with the cover bolts to see if that resolves the issue? If tightening doesn't do it, is there a more reliable brand gasket I should be running? Any other advice or tips appreciated.
