Primary locking tool dimension.
Hi All,
Going to be changing the compensator in my 2009 Electra Glide Classic in a few weeks. Can anyone give be a good dimension tip to tip on the length of the tool used to lock the sprockets so you can torque the bolts on the clutch drum and comp. I see several different lengths out there. Thanks in advance for any assistance. Mike
On my '15 limited Low it's 6". Actually 5 15/16 I think but close enough.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Khibbs (07-16-2020)
Since it's difficult to see in the picture you posted, I'm guessing the plate puller has an inner lip to reach behind the bearing race?
Odd set up though in Harleys part though. Usually a bearing or bearing race seats against a shoulder or a retaining ring of some sort to locate it. This race on the main clutch shaft was just pressed to leave a little space behind it and that's it. If you press it on too far when installing, it will compromise the seal on the drive sheaves bearing.
http://assetcloud02.roccommerce.net/...earingrace.pdf
You need one more tool. Lot's of examples on ebay and george's tool. Slight mod of your puller will probably work as a press if your hole is not to big to attach to the end of the LH thread. You need to press the sleeve on. Do not hammer it on. You need the control to stop in the correct position and hammering on that input shaft is not good on those bearings back in the transmission.
Harley had a reason for that inner race. If it goes, you can replace it with out doing the input shaft. If a free floating bearing ever goes, it's going to be big bucks to replace that input shaft.
