Going to a 6 speed transmission....what else to replace?
After a ton of research, I've decided that going to a 6 speed transmission is something that my 2004 Road King Custom will benefit from. I will be purchasing a Baker DD6 builders kit in a few days.
My question to everyone is, what else should I replace or inspect while installing this trans kit?
Couple things you will need:
Part# 95E-56B speedometer re-calibration unit.When you change from a 5 speed to a 6 speed it throws the speedometer off 7 %. This unit will correct that.
Something else you may want to consider is the High torque bearing kit part # 189-56
The stock inner primary race has a tendency to walk into the main drive gear. This will eliminate that possibility. Here is a link:
http://crustyoldsite.bakerdrivetrain...ue-bearing-kit
rick775472
06-12-2015 01:46 PM
