2005 RK clutch question.
My 95" RK runs about 95hp 95 tq.
the stock clutch with a SE spring barely holds the power (I think it does slip just a tiny bit).
Can I remover the damper spring and the cut down rear friction plate and replace them with another steel disk and 2 frictions? Is there room?
I seem to recall somebody doing this before, maybe I'm wrong?
I don't really want to increase lever pressure (my hands are bad)
and don't want to spend $$ on a whole new clutch- I have plenty of other things the bike needs right now, an extra pair of plates would be a good inexpensive fix for a clutch that is almost good enough as is.
What you may be thinking of is what is often called a +1 plate kit. Barnett and no doubt others make them, in other words a complete set of friction and steel plates. The stock clutch has a 'Spring Plate' in the centre of the clutch pack, which the +1 kit dispenses with. Will one of these kits solve your problem? I suspect not, although you may well enjoy a smoother more pleasing clutch action. Barnett also make stronger clutch springs, so one of theirs may solve the slipping problem.
An alternative to consider is an AIM kit. This is a bob-weight device, which as engine speed increases, increases clutch pressure. It can be used with a softer spring, giving an easier lever pull, while applying muck more pressure while riding at speed.
As built, the stock clutch with a 380 lb spring should hold a 95/95 motor no sweat providing the clutch is adjusted right.. I would adjust the clutch first and go from there.
You can't modify the clutch to add a plate by your suggested method. The +1 kits thin either friction / steels or all of the full plates to get +1 plate in the clutch.. Best to buy the kit. One thing to note is that some plus one kits can drag..Neutral can be harder to find at a stop with the motor running.
If the clutch has slipped much, the frictions are likely toast.. I would simply go to a stock plate count Kevlar friction plate kit from Barnett and check the steels / spring condition.. The SE spring is a 380 lb spring and should be more than enough.. I use stock early TC spring (320 lb) with kevlar plates and no issues for about 40,000 miles on 02 RK that has made as much as 110 tq and 110 hp (not at the same time).. For the previous 20K, the stock clutch held up..
If going VPC, the clutch can slip at lower Rs if the clutch itself is already weak.. Most VPCs cut spring pressure so pressure on the plate is less when the motor is not spinning fast. Best rebuild the clutch (likely needs frictions) before adding the device.
Reaper's motor dyno's at around 96 hp / 112 ft-lbs, and the stock clutch with the SE spring never had a problem with slippage. A couple of summers ago, I installed a Barnett extra plate clutch pack, and it, with the SE spring has no trouble holding the power output either.
Check you clutch adjustment, and for excessive wear of the steel/friction plates.
Cheers!
Cheers!
bvalleejr
10-12-2017 11:08 PM
steveh326
17
11-24-2011 07:57 AM
