Upgrade clutch question
grbrown, I mentioned this in the other thread. I'm looking for options to make clutch pull lighter. Thought a later model clutch might open the door to the AIM/VPC (the one for later models--I prefer its design to the Evo style); and/or for the Harley spring and ramps. The ramps I believe are a bolt in, but the spring needs the later clutch (I think). There's also a Mueller (sp?) modified ball/ramp that says it lessens clutch effort; different geometry on the *****/ramps, not an extender; problem is, Mr. Mueller is quite proud of his invention to the tune of $175 (USD). LOL. Still, from your account in the other thread, it might well be worth the investment simply to have the problem resolved (I don't look forward to readjusting the clutch every time I wash the bike (LOL))...and truth is 175 is much less expensive than many other solutions...(I'm still investigating the AMP device...) Edit: The Muller (correct sp) is $156 on JP Cycles with Gold Club...hmmmm...
I'm in the discovery phase of the problem so I'm frankly flailing around a bit, checking out the options...
Alan
Alan
It was a Mueller that I had for a while in my bike, which I removed and referred to in the above thread. It is one of several brands who say they are EZ, but use a similar approach. I don't recommend one, as mentioned in the other thread. If you still have the original clutch cable, start by replacing that with a top shelf one, like a Dimaondback!
AlanStansbery (11-03-2016)
The tranny main shaft that the clutch runs on the 91 is the same as the 98. My bet is that you can fit the 98 clutch.. The issue will be the sprocket tooth count. Some hubs have 36 tooth hubs and other are 37.. You probably need to figure out what your current clutch tooth count is and buy the same.. Check sprocket alignment.
my 85
it was tapered i put a 91 and newer mainshaft a matching drive gear then a clutch hub out of a 2000 dresser with a new starter gear on it cause i got the old style drive on it best clutch i ever had on it and i have had the bike sinse it was brand new i used to be able to destroy that tapered shaft and that early diafram clutch even more with my 96 in s&s motor
Max Headflow (11-03-2016)
trans shaft
yep the maindrive gear i.d. is a different size so it matches the mainshaft. i live up by traverse city.i used to work in california outside frisco at a toxic waste landfill i am aheavy equipment operator retired. back to the trans that splined mainshaft is a hell of a lot better than the tapered keyway one
