Need your help!!!
Need your help!!!
Hello all, I am having issues with my 98 CMC Softail and what I hope is only worn out clutch plates. I was riding yesterday and suddenly my rpm's went up and the bike started slowing. I could tell it would pull slightly until you tried to roll on the throttle then it would slip and rpm's would rise. I started downshifting as I slowed but that had no change. Transmission seems fine as I can shift through the gears but I'm not a mechanic so not 100% sure on anything yet. I do however know how to adjust the clutch so I am confident that this is not the problem. I do hear what sounds like scraping in the clutch plate area. My bike is not leaking any fluids and has a dry belt driven primary and the clutch is a Rivera/Primo. I was going to remove the 4 bolts in the clutch and check the plates but they (the bolts) felt like they were under pressure and I was afraid you needed a special tool to remove. I was hoping you all could give me some helpful info on this. If needed I can take a photo tomorrow and post it also. Thanks for any help and if you need more info please let me know.
The CMC uses a Primo Brute 3 primary drive. I believe you can still get parts through Drag Specialties easily. Any indy can help you out. You'll need to pull it apart and inspect. On CMCs with a lot of miles, I seen the front pulley splines strip out and belts brake. If you are getting some drive, its likely stripped splines. Could also be the splines on the clutch hub (as Mark says).. I've not seen this issue on the Primo clutch but have seen it on BDL belt type open primaries.
tat2dancer
05-26-2017 02:22 PM
Otis Driftwood
06-04-2008 06:55 PM
