Baker Compensator 630-67
Replacing stock compensator on 07 Road King with Baker compensator. Was wondering if anyone has had any experience with this. Any problems with chain alignment?
Also have transmission oil leak where clutch adjuster rod comes out of clutch shaft. Don't really understand what that's about.
First off the fluid level (when properly filled) is below the mainshaft. 4 speeds and early 5 speeds up to 86 shared more fluid with the side cover then 87 and later bikes.
Then there is not a lot of room between the clutch push rod and the inner wall of the mainshaft.
So for the fluid to make it's way down the mainshaft there would need to be pressure to help it.
If there is pressure than the vent in the transmission top cover is plugged or the transmission is overfilled.
You will get some shared fluid between changes but not enough to notice one way or the other.
Chuck6060
04-29-2013 11:45 AM
