Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
1989 FXSTC Tranny leak
Old 02-07-2017, 10:09 AM
Fings369's Avatar
Fings369
Fings369 is offline
6th Gear
Unhappy 1989 FXSTC Tranny leak
Well I'm posting this in here in hopes someone will help me figure out A) what I did wrong and B) what I should do next time (hopefully very soon).
So I recently replaced the Transmission main shaft seal and the small quad seal. It was definitely leaking from behind the seal as it did a mini waterfall once I pulled the Stock Pulley. I did not use a seal installer to stick it in the .05" that's suggested. First is this my problem? because I'll order it and see if I can keep the old seal or use it anyway for the next seal. someone mentioned this mystery 5th gear seal. I don't know what that is or where it is, supposedly could be my problem. Not sure.
So it's a bones stock bike except the bars and a few beauty marks. where do I go next, I can order georges mainshaft seal tool and hope it comes in friday.
This is my only mode of transport.
Old 02-07-2017, 10:25 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Installer is not a must as long as you are careful but make sure you lube both the OD of the seal as well as the ID. Also replace the pulley spacer when changing the seal. It get's grooved over time. Harley part number 33334-85.
Old 02-07-2017, 10:58 AM
Fings369's Avatar
Fings369
Fings369 is offline
6th Gear
Do you think I could just replace that spacer and the quad seal and leave the new mainshaft seal? and what about that 5th gear seal is that anything or for later models?
Old 02-07-2017, 11:56 AM
You could give it a whirl, if the seal in the 5th main was leaking you would see evidence on the outside of the pulley.
Old 02-07-2017, 01:00 PM
13RoadKing's Avatar
13RoadKing
13RoadKing is offline
I use RTV when install seals. Nobody else does, I think.
Old 02-07-2017, 05:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,482 Likes on 4,605 Posts
Replace mainshaft/fifth gear seal
Replace pulley spacer, quad seal and big oil seal.
Ignore RK13...
Old 02-08-2017, 10:56 AM
Fings369's Avatar
Fings369
Fings369 is offline
6th Gear
Ignore RK13...
Is there a big difference between the FLSTC and The FXSTC? finally figured out why I wasn't getting info on the fifth gear seal, because they just started calling it that, all my old manuals and everything up until splin shafts call it the main gear seal or MDG seal etc.
Old 02-08-2017, 12:46 PM
Softails used the same seals from 94 to 06.
Old 02-08-2017, 08:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Are you still using the pulley and spacer from 1989, or has the pulley been upgraded to the late `94 parts?
Old 02-12-2017, 05:59 AM
bagga's Avatar
bagga
bagga is offline
worn splines on the drive pulley or on the main gear where the pulley slides onto it will cause a severe leak or a loose big pulley nut will do it too. early evos had a narrower pulley-spline area than the later models and they are known to have the splines wear out and cause leaks.the only way to stop the leak is to replace the pulley, seals and the spacer with new, upgraded parts. you may need to replace the main gear too if the splines are even slightly worn.
Fscott4
05-30-2018 05:09 AM
chevdude
15
08-04-2017 09:02 PM
Kaycee
04-01-2015 08:07 PM
shadowchrome
EVO
14
03-27-2014 04:20 PM
gunnert
04-24-2009 07:24 AM
Quick Reply: 1989 FXSTC Tranny leak
