Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission Fluid coming through clutch cable
Old 04-28-2017, 09:25 PM
jimihd's Avatar
jimihd
jimihd is offline
Default Transmission Fluid coming through clutch cable
I'm at a loss. I recently bought a 2008 FLHTCU that had 1,309 miles on it. I know, the guy never rode it. Now, a couple months later it has 2,013 miles. and I have transmission fluid coming out of the clutch cable at the adjusting nut. Went to local Harley shop they diagnosed need a new clutch cable.
I changed the cable and the new cable leaks at the same place. The shop offered no ideas.
I have checked the vent and it is clear and the fluid level is correct. Any suggestions will be appreciated. Ride safe.
Old 04-28-2017, 09:38 PM
MURPHCC1's Avatar
MURPHCC1
MURPHCC1 is offline
Received 2,784 Likes on 1,356 Posts
is that O ring there?
Old 04-29-2017, 06:16 AM
jimihd's Avatar
jimihd
jimihd is offline
O-ring #14 is installed. Fluid is "wicking" up the cable in side and coming out at adjustment point behind front tire. If the O-ring were missing the fluid would come out around the cable. This is not the case.
Old 04-29-2017, 08:49 AM
MURPHCC1's Avatar
MURPHCC1
MURPHCC1 is offline
ahhh......got it........still sounds like a vent issue........too much pressure inside i would guess.....I know you said vent tube is clear.......so I cant imagine what else it would be.....
Old 04-29-2017, 09:25 PM
jimihd's Avatar
jimihd
jimihd is offline
Found it. I had only checked the vent hose. The vent nipple had been plugged by a dirt dobber. It's a wonder the little bastard didn't fill the entire gear box. Thanks for all the suggestions. Harley had suggested replacing all kinds of things. Remember, "KISS". We seem to always jump to the hard stuff. It is usually an easy solution.
MURPHCC1 (04-30-2017)
YellowHawk
03-13-2016 07:41 PM
Scudda
09-29-2015 01:20 PM
Premont Harley
10-30-2011 08:41 PM
Glide'n09
04-07-2010 10:02 PM
bg5377
07-30-2007 01:45 AM
Quick Reply: Transmission Fluid coming through clutch cable
