Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Spongy shifting.
Old 04-30-2017, 07:23 PM
Queen-of-Clubs's Avatar
Queen-of-Clubs
Queen-of-Clubs is offline
Received 1,334 Likes on 536 Posts
Default Spongy shifting.
Yesterday I noticed an issue when shifting and your input would be helpful.
Occasionally as I shift up (heel toe shifter on my Deluxe) the bike wouldnt shift and the pedal was spongy. I release the clutch and do it again and all seemed normal. After I realized that it wasn't my imagination, and I begin paying more attention, it's seem to occur between third and fourth gears. It was only happening yesterday while shifting up.
Is this a "take it to the mechanic ASAP or am I making to much out of this?
Thanks to all you mechanical geniuses in advance.
Old 04-30-2017, 07:34 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,467 Likes on 4,598 Posts
Check the linkage and make sure all connection points are secure.
Inspect the shift lever at the transmission, make sure it is not loose.
Old 04-30-2017, 07:52 PM
81rat's Avatar
81rat
81rat is offline
I would think that maybe the clutch was dragging a little on you for some odd reason or binding up somewhere , after everything has cooled down take it out for a ride and see what happens , I would not rush off to a shop just yet
Old 04-30-2017, 08:09 PM
Queen-of-Clubs
Ok, now I have somewhere to begin. Thank you both
Old 05-01-2017, 11:40 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
I'm with Dan check the linkage first.
Queen-of-Clubs (05-01-2017)
Old 05-01-2017, 12:13 PM
Queen-of-Clubs
Great! Thanks for your input, Mark. I'm looking up some "how-to's" now.
Old 05-02-2017, 07:35 AM
You want to make sure the long rod going from the foot controls to the shift lever on the transmission is free and parallel to the bike. You don't want it on an angle or binding.
Also the shift lever on the transmission needs to be tight no slop. They are cast levers and the splines will wear as time goes on. If it is loose, remove the bolt, clean it, apply fresh blue loctite and re-torque it.
If the lever becomes lose again after that it's time to replace it.
Queen-of-Clubs (05-02-2017)
Old 05-02-2017, 07:45 AM
Queen-of-Clubs
OK, thanks! I mean it. Those are very clear instructions. Since it finally quit raining, I will do that this evening. I may have more questions related to it....
Old 05-02-2017, 08:20 AM
Ask away that's what they pay me for.
dynahead951
05-29-2019 12:59 PM
01hdfxstd
General Topics/Tech Tips
09-07-2015 11:46 PM
Johnny K
08-02-2013 04:48 PM
lagrato
04-04-2010 07:50 AM
hottrocker
04-11-2008 08:20 AM
Quick Reply: Spongy shifting.
