Bike will not move in gear on the ground!
RE: Bike will not move in gear on the ground!
Ok guys I have another problem. Everything together. Trying to adjust clutch now. I have took all the slack out of clutch cable. Turned clutch adjusting screw in until I feel pressure. Backed off 1/2 to 1 turn. Locked nut. Moved lever 3 times and have nothing. Adjusted cable at mid adjuster and still nothing. Like I have zero clutch. Something to do with ramp and ball? I feel like I have done everthing right as far as adjusting it. Thanks for the help .
CAN YOU ACTUALLY SEE THE CLUTCH PLATES MOVING INSIDE THE CLUTCH BASKET WHEN YOU PULL THE CLUTCH LEVER? IF NOT SOMETHING IS MISSING LIKE THE PUSH ROD THAT GOES TO THE BALL & RAMP. IF YOU ARE SURE THAT THE PUSH ROD IS IN PLACE, THEN YOU NEED TO LOOK IN THE BALL & RAMP AREA FOR A PROBLEM.
What type of bike do you have?
I have a sportster 1992 XHL1200 and it is having the same problem.
I already replaced the clutch and clutch line but still the same problem.
I will try to see if the tranny sprocket is the problem.
On the manual, I can see that it is secured pretty well, and this makes me thinking it might be something else.
However, the only way to know for sure is to actually open it up and check.
Thank you in advance for all the responds
