Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Dry clutch change in shovelhead???
Old 05-23-2017, 10:46 AM
Tizza1013's Avatar
Tizza1013
Tizza1013 is offline
Stage IV
Default Dry clutch change in shovelhead???
Have bought a 75 shovelhead and has the belt drive and oil line eliminated already... oil got inside clutches *** I replaced the tranny seal was leaking... my clutches are kind of soaked with oil.. Will brake clean work for cleaning oil out or any other suggestion will work to clean oil of clutch fibers. Thanks ride on!
Old 05-29-2017, 11:27 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Wink
We have a Shovelhead section, where you should get a reply to that. I got oil on my '74 clutch plates, many years ago, and boiled them in detergent, which worked, but there may be a more modern way available today!
Kayakeur
Oil Archive (no new posts)
07-18-2016 10:20 PM
Beth Jacobs
07-23-2015 01:51 PM
Action8580
Shovelhead
05-11-2015 04:20 PM
06HarleyStreetBobLoveWillieGSkulls
07-04-2011 10:55 PM
standalone4u
09-25-2009 05:15 AM
Quick Reply: Dry clutch change in shovelhead???
