Primary oil level for 1989
I'm having an issue with my primary chaincase losing oil into the crank.
This link goes to a post I made about the issue.
https://www.hdforums.com/forum/prima...-oil-loss.html
While I've got everything apart I'm trying to consider everything I can.
A friend of mine suggested I may be overfilling my primary with oil.
In my oem manual it tells me that for an 89 I should be filling to the bottom of the clutch inspection cover.
In 1990 this level was adjusted to the bottom of the diaphragm spring. He suggested that the 89 level may have been an engineering mistake and that I should research and find what more experienced mechanics have figured out.
Any experience others have is greatly appreciated
Any primary oil that gets into the engine oil tank can only do so through the crankcase oil seal on the primary side. It is a known escape route for the stuff! As for primary oil level, I suspect the slightly lower 1990 level is quite good enough. What's a few ounces of oil between friends!
For future reference we have a dedicated Evo section, where you can bump into fellow owners. Call in and take a look around!
JohnM8
07-16-2020 04:09 PM
