Clutch readjusted every couple of weeks
Clutch readjusted every couple of weeks. Why?
I've installed a 37H and a Barnett heavy spring this past winter in my 103. I use Amsoil 20W50 Syn in the hole and over the last few months I have had to readjust the clutch pack every couple of weeks. The locknut and set screw are definitely not loosening up and the cable adjustment always goes back to the same position. Any ideas? Are the friction discs wearing thin?
Are you following the manual?
Frictions really don't wear unless the clutch is slipping a whole bunch.
What changes is the lever gap. I start out at 1/16 the 1/8 and after a few weeks it increases to 1/4 to 1/2. I end up with the clutch not completely disengaging with the lever fully pulled in. The I have clutch drag.
I checked the manual and I'm doing it correctly. "go back to the same position" means the cable adjustment measurement between the 2 cable housings or exposed threads ends up being the same every time. I.E. the cable is not stretching.
I would check the throwout bearing in the right side of the bike where the cable goes.. Another possibility is that the clutch hub is nut is slowly loosening, something wrong with the hub itself. Main mainshaft bearing on the right side might be going but you'd probably hear that..
If the frictions were wearing, you'd actual have the clutch play become less.
You are correct that that cable is likely good.
Thanks, that helps a lot.
