Clutch cable housing
so i replace my shifter seal,and others inside my primary ..replace everything by the book...now i have no clutch cable engagement..i released the clutch basket adjusting screw,and also the brake cable adjusting nut..NOW i may have moved the clutch LEVER handle once or twice while working on this....my question is, could i have release the clutch cable inside the clutch housing. ? causing my to not be able to engage or adjust tension on the handle to spec/
mi2az
08-01-2011 06:03 PM
