Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Dry Clutch vs Wet Clutch
Old 12-08-2017, 08:42 AM
sleeper80's Avatar
sleeper80
sleeper80 is offline
Stage I
Default Dry Clutch vs Wet Clutch
Have a 1993 Moo Bike (Harley Davidson)
Raised ring on block has gone back and the shop says to go to a dry clutch. What will this do to the operations and valve and appearance.
How about maintenance.
Old 12-08-2017, 02:22 PM
bustert's Avatar
bustert
bustert is offline
more info is needed.
if i had a rather, it would be wet because it is wet, if a dry clutch becomes wet, all kind of issues and drag will be one. also depends upon what friction material you use, some just dry, some just wet and some either way. the way you are going to activate it matters too.
Old 12-09-2017, 10:01 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,252 Likes on 3,626 Posts
With the busted ring, going belt drive / dry clutch is not a bad idea.. Ventilate the primary covers. I put about 44K on a primo rivera, Did replace the belt at 30K Have a evo bobber with BDL open primary. Needs rebuild at about every 16K..
Old 12-10-2017, 06:03 AM
81rat's Avatar
81rat
81rat is offline
IMO -- the dry clutch --- unless you do a lot of slow maneuvers where you would need to do clutch slipping
Old 12-10-2017, 07:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,497 Likes on 4,612 Posts
Replace the ring gear or clutch outer shell and keep the wet clutch configuration.
Your shop is trying to sell you something you don`t need.
Old 12-10-2017, 08:29 AM
Max Headflow
I think he talking about the motor case lip that holds the o ring to seal the inner primary.
Old 12-10-2017, 08:42 AM
bustert's Avatar
bustert
bustert is offline
you are a very patience man mr. max, every 16k rebuild would be unnerving. of coarse, i can't complain, my mistakingly over built 305 honda had to be upper end rebuilt every 3 run, as the rings would shatter. after the second crank rebuild, i trashed it.
Old 12-10-2017, 11:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Man did I read that wrong....
May have been caused by installing the inner primary cover without first loosening the transmission and engine mounting hardware...
mooch78
10-02-2017 04:37 PM
snookedsteve
03-14-2017 01:00 PM
deedee4150
07-07-2013 12:29 AM
bherr
06-17-2013 08:47 PM
ULTHD
05-20-2006 09:05 PM
Quick Reply: Dry Clutch vs Wet Clutch
