Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Trans Sprocket Locking Tool
Old 01-10-2018, 03:39 PM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
Depending on the back rim style. You can lock the wheel with broom handle and swing arm. Not recommended with spokes. Having someone else sit on the bike while holding brake works. Higher gear will help.
Old 01-10-2018, 07:40 PM
Jamn's Avatar
Jamn
Jamn is offline
Thanks for all the input gentlemen. I should have just done this in the first place. I'm buying the tool for myself.
Old 01-10-2018, 09:33 PM
silveradoman2's Avatar
silveradoman2
silveradoman2 is offline
Don't beat yourself up over it. You'll be glad you did
I've been there and will do it again. I do love having a new tool hahahahaha
Old 01-12-2018, 02:41 PM
bustert's Avatar
bustert
bustert is offline
more fun in making your own, though. got a box specially for such items. locking the pulley is simple enough.
Old 01-12-2018, 07:43 PM
Jamn's Avatar
Jamn
Jamn is offline
I considered that too and I have made some in the past. But I'm swamped at work this time of year so I'll buy this time.
Old 01-12-2018, 09:06 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,252 Likes on 3,626 Posts
Got any pics?
Old 01-13-2018, 05:05 PM
bustert's Avatar
bustert
bustert is offline
this would be a good thread or sticky: home made tools
when i do not have, junk pile and make, sometimes back to the junk pile after done.
some more complicated ones, i keep in a special box. as far as taking the pulley off, special tool not needed as well as going back on as i mentioned, just a piece of aluminum flat that fits the tooth and a frame member. i figured a tom terriffic hat was not needed. now if you are talking about one benched, then i would probably make one, but since it is easier to remove the pulley on the frame, never saw the need.
but bird is in hand, have a fxst with tranny issue that i might look at since the primary is off and have not gotten to pull the swing arm yet, tooooo cold.
Greabert
06-03-2013 11:54 AM
Derekj
04-15-2013 09:41 PM
BLK107
02-07-2013 03:07 PM
HOGRIDA_06
03-30-2010 12:21 PM
Fossil
09-08-2009 07:20 PM
Quick Reply: Trans Sprocket Locking Tool
