Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
20mm belt life
Old 04-16-2018, 03:55 PM
sbrmike's Avatar
sbrmike
sbrmike is offline
Default 20mm belt life
I have a 2006 Softail with stock driveline to include engine. How does a 20mm belt's life compare with a 1-1/8" belt?
I recently went to a narrower wheel/tire and have room for a wider belt if there is much to be gained as far as life expectancy of the belt.
I am not planning on changing until I need a new belt if I change then. It looks like I will need a spacer to move the sprocket and belt outboard a bit. There is 5/16" difference in the belts; the sprocket pulley is not that much wider, so 1/4" spacer may do the trick.
Old 04-18-2018, 08:31 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Having owned a bike with the original 1 1/2" belt, I'm going to guess that the later narrower belts are at least as good as the previous wide ones. Manufacturing techniques and materials have moved on a lot since the first belt-drive Harleys were introduced in the 1970s! I would observe however that the trikes all come with a 1 1/8" wide belt, so the narrower ones are not considered man enough for them just yet.
kiwiharleyrider54
17
10-16-2022 05:07 PM
madwrencher
02-03-2019 08:36 AM
TFPops
06-19-2013 08:38 PM
jsbridgew
11-26-2010 12:16 PM
LowriderFXRS
06-09-2007 04:59 PM
Quick Reply: 20mm belt life
