do I need a drive belt??
So I dont know if Im posting in the correct section. if not my bad. So I took my wheels off to change tires and this is my first harley. Got almost 20yrs on street bike but they are chain drive. Could some one tell me if i need a belt or if this is normal wear. How long do these last? Thanks for the help
Wanted to add bikes a 2009 heritage classic 6400 miles
Hmmmm- with that kind of milage- thats alot of wear and very uneven. Ive never owned a softail- maybe its a softail thing? My belt on my 92 flhs had 2 holes in it and still lasted 80000km. It was worn- but not as bad as your photo. Check your sprockets for junk stuck in it- check sprocket alignment- make sure sprockets are tight.
if the wear on your belt was more to the center- id say use it- but its the edge- so for piece of mind- score a new one. Sorry.
Max Headflow (07-04-2018)
Agreed. OP it looks like you picked up a rock or something. I have 40k on my bike and my belt doesn't look anything like that. Inspect both pulleys real close for damage.
Yeah- if you got a ride this weekend- slap it together rotate your wheel- make sure the belt is tracking on the pulleys ok (not trying to jump off sprocket)- and go ride- just keep checking it for tears on the edge or loose nubs. Since its half apart- if i could get a new belt today- id go get one. All said- these belts are pretty strong. Up to you.
