Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Ok 100the anniversary but engine heads are casted screaming eagle.
I am finking to chainge it by my self. As the harley shop is wayyy expensive. I am car mechanic so I fink I will be fine 😑
I was wandering about baker DD6 is this kit just for 6speed?
So someone added the parts. They weren't delivered from the factory that way.
Yes you can install a DD6. It only fits early TCs with the 5 speed. There are some special tools needed but the task is not too hard.
ok i will try to contact. Thenks
maybe the qustion is dtupid but what are benefits in DD6 ?
Lower rpm's at highway speeds for a smoother ride, less wear and better gas mileage, Quiet, smooth, positive shifting, easy to find neutral and a 5 year /50,000 mile warranty.
