Clutch is sticky
multiplate wet clutch, they do stick together a little when cold .
If it is ok after warming up then don't worry about it .
All four of my HD,s stick after sitting for awhile. (a little lurch when shifting from neutral to first.)
tip , first shift is to give it a healthy punch when putting in gear , don't ease it. =grind
One thing you can do is start it in gear first thing in the morning.
that will free up the plates,
hopes this helps
hopes this helps
Leszek Jak To Piwo (12-06-2018)
you fill it just enough to bring the oil to the bottom of the clutch pack...now the part I can't answer for you is should be on the jiffy stand or standing straight up while doing this. .because I'm pretty sure different bikes have different techniques. Find out that out then fill it just enough ...dont go by the recommended amount because it may be too much and you'll definitely get drag and it will be hard to find neutral too. Maybe someone with a softail will give you some info. Hope thst helps
