Inner Primary Sealant
I have a 2001 Ultra and am going to be putting my inner primary back on. What and where should I use to seal the 5 bolts that are inside the primary? It looks like there was a small amount of sealant where the bolt holes mate with the engine case and the transmission.
Lots of sealant options. Make sure you remove all the old sealant and there is no oil in the bolt bore; it will not compress and some have blown out the bottom of those bolt holes. Chase the threads with a thread chaser if you have one, if not, use a tap and blow the hole out. Thread chaser is better than a tap an the chaser isn't meant to cut threads but a tap is OK, just don't do it every time.
hAkron
05-26-2016 07:47 AM
billymons
05-31-2009 10:52 PM
