Another primary issue.
Hello,
Today I installed my pro-pipe and went riding. Because I love the roar from my exhaust I was riding like a dick.
When I took off from the intersection my bike started shaking and vibrating like the wheel was falling off, but it would settle down if I coasted with the clutch lever pulled in or if I cruised at low revs but came back if I rev'd it with the clutch in.
I've had a suspicion my clutch hub bearing was on it's way out so once i got home, after i finished being sad, I pulled the primary off.
Comp was still tight so I pulled off the clutch hub. Could this have caused the shaking and vibrations?
Thanks for any tips.
See that a lot. Usually not that bad. Mine has just corners gone. Is the spline what positions the clutch hub? When you see just corners gone, is that from the initial factory torque? I am not sure why flogging it would just take corners.
Flogging it will take the older style alternator rotor 10 spline out.
When I got one from dealer, he told me he still sells about 10 a year for the older style bikes.
You might want to make sure alternator rotor is not gone. It is like a flywheel. And compensator spring will drive it, so it can be hard to see it is loose. Compensator can still be tight. Check your rear drive pulley on your wheel also.
