Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Starter. Clutch release sensor
Old 05-18-2019, 05:50 PM
GeezerGlide17's Avatar
GeezerGlide17
GeezerGlide17 is offline
Default Starter. Clutch release sensor
My 2017 FLHTCU will not start in gear with the clutch pulled in, it will only start in neutral. Is there a sensor or switch that needs replaced in the lockout system? I hope I have explained my problem correctly.
Thanks,
Old 05-18-2019, 07:14 PM
dawg's Avatar
dawg
dawg is offline
Received 2,954 Likes on 1,711 Posts
Old 05-18-2019, 07:37 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,246 Likes on 3,624 Posts
You have to replace the left handlebar switch assembly. Pricey..
Try this,,
https://www.hdforums.com/forum/milwa...tch-issue.html
Old 05-19-2019, 07:14 AM
GeezerGlide17
Thanks very much for the info!!!!!! I found the switch and pushed it about four or five times and it now works as it should!
I really appreciate it.
P51Driver
2018+ Softail Models
19
07-22-2020 03:39 PM
Guntoter
11-03-2013 08:08 AM
knights
06-26-2013 06:51 AM
bloodyhead
09-05-2010 08:56 AM
pip369
08-19-2009 09:12 PM
Quick Reply: Starter. Clutch release sensor
