Howling/grinding noise from trans
2009 Ultra Classic w/31,500 miles.
I may have an expensive fix on the horizon.
Start the engine in neutral, howling/grinding noise from trans at idle.
Put it gear, noise stops.
Shift back to neutral, noise returns when I release the clutch.
Noise it present in all gears when bike is moving and is consistent with speed of bike and gear selected.
Just changed the Primary chain tensioner hoping that was it.
Possible transmission input shaft bearing or clutch disc noise.
Shifting smooth, runs smooth in all gears.
But that noise is getting louder.
While you're checking things, check the clutch hub bearing. I had a 2009 Ultra Classic that had the clutch hub bearing go bad @ 37,700 miles. Sorry I can't remember the specifics of when the noise would start or stop because it was back in 2010. To the best of my recollection, it sounds very similar to what you are experiencing. On mine the shop replaced the Clutch Assembly HD P/N 37813-06A. The primary chain tensioner was also fractured and replaced at the same time.
Talking with a buddy at work who said the same thing. Although he said the clutch hub bearing failure caused his bike to lose the clutch so he couldn't shift or come to a stop.
He spun the bearing race in the clutch hub so he had to replace it all.
He said what you guys are saying. Based on when the noise happens and the fact that it is shifting normally means a Inner Primary bearing.
Don't really need any special tools to do this job. 13/16 ths socket for the compensator and something to lock the primary chain up and it comes apart. Inner primary had to come off also, which requires some sockets. Should be able to do this in an afternoon taking your time. New primary bearing, gasket and new seals where needed. Make sure your trans shifter is tight while you have it apart.
RPDLV (05-29-2019)
Awesome guys.
Thanks for the insights.
Been a mechanic for about 30 years but never on motorcycles. Cars, tractor-trailers, forklifts, buses and currently Firetrucks.
But no bikes.
Sounds like the clutch hub comes off without a puller or special clamp. Wasn't sure about the bearings though. Sometimes they require a puller.
But no bikes.
