miss in 3rd gear or surge
Hey i have a SE 2017 road glide with i miss or more or less acts like it jumps a tooth on belt . It only does it in 3rd above half throttle between 3500 and 5000 rpms . I just replaced the rear pulley cushion because of a lot of play in it and now it does this . It doesn't do it in any other gear or if not over half throttle in 3rd . I am thinking maybe compensator but in my experience if that was the problem it usually does it in other gears and throttle positions. Swing arm bearings are tight and put in new wheel bearings . I have also put it on my dyno to see if it was fire or fuel related and it isn't . other than that runs great and no codes .
Max Headflow (07-11-2019)
Jason LaRev
10-16-2017 03:36 PM
AAAC
06-11-2015 08:59 AM
