2024 Road Glide - need easy pull clutch
Hello,
Looking for people who have successfully installed something to reduce the clutch pull pressure on a 2023-2024 Road Glide cable clutch. Getting a 2024 Road Glide next week and need a lighter pull on the clutch lever due to sore over worked hands. Thanks in advance if you have found a solution for your bike.
Steve
Steve
So long as the ball and ramp pieces are the same as prior, the Muller or easyboy ramp should fit a 24. I’m coming off a 19 with a super easy pull because of Muller slave on the hydraulic clutch and going back to cable on the 24 so will be putting something in to make it easier.
Thanks.
steve04
2014-2023 Touring Models
14
12-06-2023 09:38 PM
