Baker Clutch(s)
Has anyone tried either of the Baker clutches? [/align][/align]http://www.bakerdrivetrain.com/clutches/index.htm[/align][/align]I know I'm gonna need a better solution with my upcoming build & I was considering one of these.[/align][/align]If I read correctly, you have the ability to swap gears on the basket w/o swapping the whole basket. "Assuming" the gears don't cost as much as a basket, this seems pretty sweet.[/align][/align]I am anticipating 130+ ft/lbs of torque, so that seems to point to the KKK.[/align][/align]I am curious is anyone hase used either of these unit and what if any feedback you might have.[/align][/align]Good setup?[/align]Lever Pull - hard/easy?[/align]What fluid?[/align]Any fade when hot?[/align] |
RE: Baker Clutch(s)
I have not tried it yet, we are direct with them as a dealer but cost wise they are on the pricey side. We use the Primo drop in clutch pack and they rock. Lever pull is light, and they hook and hold with no issues at that level. I have tested the primo in a stock outer basket to 156 tq and after a seaon of riding no issues at all. No we do use the billet outer basket when going to a 3.37 gearing and those have proven to be bullet prove as well.
RE: Baker Clutch(s)
Thanks, Steve. So you are running the Primo on your Deuce? I'll check them out.
One thing that is intriging about the bakers are the interchangeable gear, although I have no idea how pricey those are. |
RE: Baker Clutch(s)
One of the guys I ride with has a Big Bear and an 06 Ultra both with R&R motors the BB has a 155 the Ultra a 124 both with the KKK(because he loved it in the BB). Light clutch pull and no slipping
RE: Baker Clutch(s)
thanks Joe!
That is exactly what I was hoping to hear! |
RE: Baker Clutch(s)
Go with a primo pro clutch . I have two of them . One behind a 113 in my bagger and one behind a 150+ hp built 124 . They preform perfectly and have light clutch pull . They also give you a choice of springs . For your application the silver will be the best . They are hard to beat ! I sure the baker units is a good unit also .
RE: Baker Clutch(s)
Phil, I think based on what I heard today.....I am thinking we dont want to be first on this one, sorry it tookme so long to find out anything.
RE: Baker Clutch(s)
OK.... thanks guys.
So, I guess it'll be the Primo then. I'll be in touch, Bart! |
RE: Baker Clutch(s)
You want be disapointed !
RE: Baker Clutch(s)
Phil, you still going with the KKK...I did order the Primo Pro Clutch from Bart.
© 2024 MH Sub I, LLC dba Internet Brands
