Help with 6-speed gear set selection
I'm planning a 95" build along with this switch. Should I look at one set over another? How much attention should I give to ratios, helical versus straight cut, etc?
Considering a 6-speed gear set conversion in my 06 FXSTS Springer. I started shopping around and found some with very different price points. Source for these estimates is J&P.
SE, S&S, and Baker retail around $2200-2500. Not sure about the SE kit but the Baker set has helical gears for 4-6. S&S are all helical cut gears.
Then I found a set from RevTech for about $725. It appears that the RevTech gear set is straight cut gears. Are helical gears worth the $1500+ price difference? Or is there some other reason for such a price difference?
Aren't the stock gears in 06 Softails all straight cut?
I've had a REVTECH 5 speed behind my 113" Ultima iin my softail for 5 years and I beat the snot out of it. Never had a problem, shifts great, smooth and quiet. I just installed their 6 speed gear set in my bagger behind a 95, haven't had the chance to try it yet because of all this damn snow we got, but I'll keep ya posted...
the prob with revtech is the 6 speed,not the 5 speed.5 speeds are just a copy off a HD 5 speed,the prob is with the 6 speed,insted of copying a baker(like everyone else did)CCI decieded to desighn their own 6 speed,well their design enginers messed up,all other 6 speeds use a thicker trap door and put the extra 2 gears there.revtech decided to have stock width door and skinny up the gears,not a good idea,theve have a mess of recalls and problems(with shift forks too).we did warrantty work on them until CCI would only pay to replace the recalled parts,not taking the trans out & reinstalling it,wanted shops to eat that part,screw that.since youve got one,good luck with it,but buying one now,ide look elsewere
Thanks for the replies! Just based on write-ups and Baker's reputation in general led me to believe that the Baker gear set might be the better buy.
Any consideration with gear ratios and larger engine builds? I am planning a 95" build. I heard rumors that the 07+ 96" HDs power output is somewhat restricted by the use of the gear ratio's in the stock 6-speed. Don't want to do the same with my 95" build.
