ATF in primary
You can use any type you want. The type F slips less then the others though. As well as the B&M trick shift. I have been using the Dexron III myself as Im not pushing a lot of HP at this time. It gives a nice smooth engagement. Try em all and find out which one you like best. Start cheap and work your way up to the syn types.
There's an article on clutches in the June issue of American Rider. Joe Minton said that ATF is a poor choice for the primary. His reasoning is that while it is fine for the clutch plates it is not good for the chain and gears over time.
Not sure he is correct as I have used ATF on and off for years without issue.
