Crank bearing behind compensator
I have a 2007 Ultra and last fall I had to replace the compensator. I washed out the stator with contact spray and blew with air and ran white cloth behind stator till i was confident that nothing was behind it. Replaced with the screaming eagle kit. It still looks like a poor system but at that time that is all i could get.
My question is: Is the crank bearing on that side a sealed bearing or is it open to all the junk that floats around in the primary? Now that I have time to think about it, it is on my list of concerns. Thanks, Jim |
It is a open roller bearing, has been since 03 when they did away with the Timken.
Thanks Mark,
What keeps the primary oil from mixing with the engine oil? I know you drain two different compartments, and refill in two different places? Thanks, Jim |
It is sealed from the primary by an oil seal that is installed into the case.
New comp that Darkhorse is releasing soon.
http://i1220.photobucket.com/albums/...9931500656.jpg http://i1220.photobucket.com/albums/...9931479059.jpg |
New solution for the lack of oiling with the SE comp.
http://i1220.photobucket.com/albums/...1-01-14_81.jpg |
Looked at Ronnies and found only one brg on that side.
No worries now. Thanks, |
Originally Posted by soft 02
(Post 10888369)
Not sure. Call Darkhorse for the latest.
© 2024 MH Sub I, LLC dba Internet Brands
