transmission dipstick stripped on the Allen head
I went to check my trans oil and the top of the bolt head that holds the O ring snapped off so i had enough to get my allen wrench in and thread taped it and put it in. i went to check the fluid again before i left a rally and stripped the head. Dont know how to get it out without using a welder and thats my last resort. Any help would be appreciated. im going to try and get a picture up from my phone
Remove the cover that the dipstick threads into, and take it to a shop.
A good four wheel drive shop will have that part out in a jiffy, they are always removing stuck differential fill plugs that are so tight they might as well be welded in...
And you might think about how you got into this fix. There is no reason the dipstick should be tightened into the cover, it just needs to be snug.
