Screamin' Eagle Clutch Pack Installation Problems
Hello all. I searched a lot of different ways to find anyone else with this issue but came up empty so I figured I would start a thread. I am in the process of changing the stock clutch discs on an 09 FLHTCP 103" Harley to the SE Clutch Kit Pt#37980-10. My problem lies when I try to install all 9 friction discs and 8 steels there seems to not be enough room. When I try to install the clutch spring and tighten it down it wants to compress between a 1/16 and 1/8" before it bottoms out and that seems a little too much to me. I did remove the damper spring and damper spring seat so I know that is not the issue. Just for chits and grins I took out 1 steel and one friction plate and it seem to go together fine that way but that does not seem right either. Is there some depth adjustment on the clutch basket itself? Can someone please help?
Thanks,
gerby
Thanks,
gerby
misfitJason
06-15-2014 04:42 PM
missedem
05-04-2014 10:22 PM
