Blacksonne88 |
07-25-2014 08:16 AM |
High pitched squeaking
I have a 2006 dyna glide, TC88 it's got 16k miles on it. In neutral there is no noise. Only between about 1500-350rpm do I hear this squeaking sound. But it sounds like it's coming more from the front of the bike than the back. Like behind the points cover or under the filter. But it's hard to tell and with it not making the sound unless being in gear that makes me more confused. I looked at motor mounts. It's had the inner primary bearing done. It's got the hydraulic tensioner, any help would be much appreciated. Fluid levels are correct. Thanks a lot.
