How much weight?
When you're loading up, how do you guys decide what your max weight should be?
GVWR? Tire rating? Trial and error? |
One map light of needing a trailer...
https://cimg4.ibsrv.net/gimg/www.hdf...291f6e52b.jpeg 1,200 lbs wet, all-in, on a 13,000 mile Alaska Rounder, via California & Ontario ... dog stayed home. |
Would like to say we do all that, but can’t. :icon_shrug:
Crank up the preload, check tire pressure, get the heavy stuff as low as possible, and go. So far so good. |
I have 15 lbs in each saddlebag with my tools on the bottom.
I have 28 lbs in tour pack. I have 20 lbs in waterproof bag in passenger seat. I have a 1.25 gal rotopak gas container on tour pak rack which, when full, weighs probably 10 lbs. I run 30 lbs of air in shocks and 38 lbs in front tire, 42 in rear tire https://cimg6.ibsrv.net/gimg/www.hdf...6d7d828fb4.jpg 2 lbs in rear tire. |
To be honest I've never considered weight. I can only carry so much on a bike and figure at most it would add up to having a hefty woman on the back as opposed to a little one
I see 400 lb guys with 350 lb old ladies all the time riding. Keep things balanced and you'll be alright.
Originally Posted by piper59
(Post 18324254)
Originally Posted by A#1
(Post 18322736)
I have never really worried about weight. Just make sure my rear tires are at 42 lbs and front at 40 lbs. I never have a passenger so I look at all my luggage not coming close to what a passenger would weigh
Originally Posted by davey019
(Post 18324955)
© 2024 MH Sub I, LLC dba Internet Brands
