Question about Vance Hines Hi Output pipes
I have VH monster ovals on my 2010 CVO Ultra with VH. True dual headers and Screaming Eagle tuner. I was thinking about changing the slip ons to the V H hi output. Wondering if anyone has these and can give me some input on them. Also wondering what that would do to my tune.
The Hi-Output Mufflers are designed for the higher output HP motors. They say like 120hp and up and bigger cubic inches. that being said, I put them on my SG for the looks they gave. To me they sound great (not to load, but you here them), but I would bet they hurt you a bit at least on the dyno. I'm sure some of the others would be better if you are trying to squeeze every little hp out of your motor. I personally think they hurt a little in that they don't give my 103 enough back pressure.
One other downfall on these mufflers is that they are as big as they are. Coming out of driveways that have a dip or enough slope, they will hit or drag. I have also dragged them a few times in the tighter twisties.
Have them on my 08 CVO Roadking. I put extended hard bags this year and wanted the biggest muffler I could get to fill the cut outs, and they do just that. They will not scrape on the turns unless the bike has been lowered alot. They may scrape if you have a dip at the end of your driveway or parking spot, that I have not had to worry about. Will they reduce the power of our already anemic motors? Mine seems to run just fine. Sounds great when cracking the throttle, not too loud when cruising, and a real nice gurgle when letting off the throttle. The only thing you may notice is a little bit more vibration, as the hangers use an adapter that mounts to the inner side of the muffler as opposed to the top. The inside of the endcaps will get sooted up after a long ride due to baffle being one continuous piece that empties into it, rather than a tube that sits inside of the endcap. Easy cleanup and if you have black end caps then this wont matter. Mine are coupled with Vance and Hines true duals and I am very happy with the set up.
I've had the HO's on my '14 SERK for 3+ years and like the look, sound, and performance - although I'd go to a 2 into 1 if performance was my highest priority. Re the tune, if you had the bike tuned with the Super Tuner and MO's prior to the EPA stuff HD went through, I'd put the HO's on without a new tune and see what you think, it's probably better than what they can do today, anything they do now for that setup will run lean and hot. I wouldn't use a Harley dealer for a tune at this point, I'd go to a good independent tuner, if the bike doesn't seem to be running right after the swap or it's worth a few hundred bucks to you to just dial it in then do that.
