Brake lights 2015 CVO Limited
Can someone with a 2015 CVO Limited tell me if the tourpac lights function as brake and directional lights ? My corner lights are only working as directional and running lights. The center light is working as a brake light.I do have CD led's in the lower lights. The dealer thinks they are working as normal for that bike. We didn't have a 2015 to compare to bur all the other bike have the brake lights in the t/p working with the directional. Thanks for the help. I told the dealer I would find out if this is normal.
I was checking the lights on my 14 CVO Limited this past weekend before I took the bike out for a ride. The tour pak had no brake light functions, just running and signals. If that bothers you, get the light bar that goes under the back of the luggage rack on the top of the tour pak. It has running and brake functions. I have one and I like it.
Custom Dynamics has modules to make the turn signals Run-turn-brake. Your required to run red turn signals when using it. I have one of these on my 15 CVO RGU which I believe has the same rear lights as your Limited. CD also makes modules to make the tour pack operate as RTB but not sure if they fit a CANBUS CVO or require other components.
