Hard starting when hot 110SE
Hi all, I'm stopping by from the Dyna forum. My 2016 Low Rider S came with a factory 110SE motor, which I believe has been in the CVO's for a few years now.
My problem is I am having recurring hot start problems. In the morning it's fine, starts right up no prob. However if I try and restart when the motor is hot, say stopping for gas, or anything less then a 30 min wait or so, 8 times out of 10 it will slow crank one turn, pop a voltage insufficient error and either turn over again and eventually start, or equally often the compensator will kick back with a loud clank.
Dealer had tested the battery and charging system and found no problem (fwiw)
I replaced the battery with a 310 Yuasa that started equally quickly when cold, but same vinerr and kickback when hot. So it's not the battery.
The bike is about 3 months old and has only 2500mi so I don't think it's a terminal corossion problem either. Plus the easy cold starts would eliminate that as well I think.
I'm going to check the starter and ground terminals later today, just to be sure, but I wanted to ask here since there are more of the 110's here then in the Dyna forum.
Any suggestions are appreciated. Thanks.
benscratchin (12-12-2016)
