117ci 2017 108HP ~ 121TQ
Stage III... I have 4.5 Rineharts slip-ons only. Had a Dyno tune done here at 1900 miles w the Street tuner.. Bike runs way better!! Snappier, pulls better.. Very pleased indeed.. because the bike tops out at 110mph it has to be done in 5th gear to get a good measure, the HP never crosses the TQ line cause you run out of speed. Fun Bike.
Here is a stock CVO 114.
Here is one with just a Head pipe, slip-on and a Woods 222 cam. 116.66 HP and 123.46 torque
I believe he is saying it hit it's speed limiter before 5250. Wonder if he could run it to 5800 with the speed sensor disconnected?
Edit: he is using the Street tuner which will not let you remove the speed limiter. FM uses the PV which will allow you to remove it.
