Has anyone installed the SE high flow exhaust headers on a CVO?
Well, what the hell, guys, I'm gonna go for it. I'm getting the High-Flow system installed and the SE wide band 02 sensor along with it. I can probably post up some sound bytes once it's done, but I won't be able to post any riding comparisons since we are currently well and fully snowed in up here and likely will be for the next six months.
Anyway, that's my update... for now.
r
r
I have the HD high flow exhaust with cats in the mufflers on my 17' CVO Street Glide. Before I out that on, it had a V&H header with V&H mufflers. The exhaust is definitely quieter than the V&H system. Power feels about the same. I'm going to probably put the Stage 2 torque cam in soon if I find a dealer doing that and a 10k service at a reasonable winter rate. Hopefully the exhaust will make good use of the torque cam.
as long as the parts used are epa compliant it will.
the touring mufflers are different sized than your softail mufflers. probably a lot higher demand for cvo touring than there is for cvo softail.
Hey Gunny, How are those working out for you? I have an 18 CVO SG and need to hear my pipes. Just got through the break in period and ready to do a little something. I am not looking at the headers (yet) but at least for now, I have been mostly looking at the Fullsac 2.25 baffles. I think I will go without the blankets as it reduces noise 2-3 db (so I read). Are you using all of the original matting or did you strip some of that away? How is the sound? I am assuming no performance enhancements as it is only the mufflers.
ChrisHall
Screamin Eagle CVO Models
19
07-31-2019 12:51 PM
